Results 1 to 7 of 7
Thread: 901-0 Transmission question.
    Aug 2017
    Toronto Canada
    Would anyone know how to decode the 6 digit code, 101911 on this transmission? Name:  1FD1EAA5-3455-444B-A61C-5BACAA6EBA50.jpg
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I thought that all the 901/0 (for 5 speed boxes) serial numbers were sequential starting from, 100001 through to 102282 in July 1965 and then for 66 cars they were 221xxx and 222xxx etc up to at least 232xxx
    So this would be in a car built about July 1965 with a vin in or close to the 3018xx range
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Quote Originally Posted by Amantella View Post
    As Hugh said, the 6-digit serial number was sequential in 1965, and did not contain a code.
    Type 901/0 was a 5-speed for 6-cylinder cars, with gear ratios 12:34, 18:32, 23:28, 26:25, 28:23 and a 7:31 ring & pinion. Your axle flanges have been changed from Nadella to Löbro.
    Jon B.
    Vista, CA
    Aug 2017
    Toronto Canada
    Thank You Gentlemen!
    Junior Member
    Sep 2017
    I have the same one !
    1968 porsche 911L targa goldengreen with red interior
    Junior Member
    Sep 2017
    Question
    Do you know the value of this transmission ?!
    Quote Originally Posted by dondi View Post
    Installed in your car and working well: priceless.
    Jon B.
    Vista, CA
