Results 1 to 9 of 9
Thread: Wiring help #2
    Dec 2013
    Connecticut/Florida
    Wiring help #2
    These connections are just inside the passenger side front trunk. 5 connections. Also, the wire that goes near the trunk lid connecting bracket - on the top left of photo - appears to go up and then behind the passenger fender/door area. Not sure where to. I know that restoring my 914 there were some wires for various options that were not used. Perhaps those are these. But I believe one of them is for the trunk light.
    1971 911S Coupe - Gemini Blue
    I just stripped my ‘69 T to get it ready to paint and I think that was where the wires for the convenience lighting in the headliner were routed - basically behind the fender and then up the A-pillar IIRC.
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by rac390 View Post
    Ok, than,so I’m thinking these connect to
    Trunk light
    Interior light
    Door switch ?
    Here is some info.....Name:  B170BAFA-2432-4D3D-8082-CB214A931A95.jpg
Size:  78.7 KBName:  64F7087C-5A6A-425C-8A37-0CEA42A841AA.jpg
Size:  91.6 KBName:  52ABB4C7-1184-4C48-87B5-465B2561B0F5.jpg
    The wires laying down show the raw end feed for door switch
    The other black and brown connect to the ceiling lights ( note the male ends connect-to the female ends)
    You can also the the black/white stripped connecting to the interior hood lights , also the raw end to the switch that actuated the trunk lights.
    Hope this helps.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by 71gold View Post
    Hope this helps.
    Thanks ver much
    Dec 2013
    Connecticut/Florida
    So I spent some time looking at all the wiring...there are two sets of wires - one that comes from the Interior light and down into the trunk and the second that runs under the cowl from the drivers side.
    I have 5 connectors 3 Female and 2 Male. I am missing the harness that goes up to the switch and the light itself. I am trying to understand what connects to what.
    Just to clarify ...this is for your 71S coupe..correct ?
    I will review again
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Dec 2013
    Connecticut/Florida
    I will review again
    Frank
    Frank yes thanks
    Ok....the photos I had shown were for my 70 targa, although may be similar I decided to reviewmy 71 Sunroof coupe...
    I have it stripped down and all areas your concerned about related to wires I photoed this morning.
    So there are 6-7 photos and will take too long to post so send me PM with your email and will send.
    Here are a couple for others interested.
    FrankName:  2394CF2A-885F-4F2B-912F-6EBF2990C00C.jpg
Size:  108.0 KBName:  D3E5B48A-9EC0-414A-BB06-B1484FFEC82B.jpg
Size:  94.3 KBName:  F37F04CA-5BB0-491F-ACDB-E1082FE57307.jpg
Size:  107.1 KBName:  A941C888-0356-4330-B27D-D5D1DE0AD7A3.jpg
Size:  94.8 KBName:  B5D1212C-2D59-48FD-9781-20C7DE37BDA0.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
