Thread: Frozen Sunroof Cable
    Just found the cause of a non moving sunroof in my 911. After removing the sunroof panel, all the aluminum rails and dropped the gear drive. I tried pulling on the passenger side sunroof cable and it slides in and out of the routing tube just fine. But then I tried pulling on the driver side cable and it's frozen tight. Was thinking of shooting some PB Blaster down the tube entrance that the cable inserts into, but the diameter of the cable is just a tad smaller than the diameter of the tube opening. So unfortunately can't get the PB blaster far down the tube. But sprayed the tube opening as best I could. I was thinking of maybe using a heat gun to heat up the cable with a heat gun. Perhaps the heat would conduct along the length of the cable, thus expanding the diameter of the cable just enough to break it free? That's assuming it's rusted somewhere to the inner wall of the tube it's routed through. Any other ideas on how to tackle this one?
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    Do you think the cable is bound in the aluminum side track. If so you should remove the side track with the cable and work the problem on the bench.
    Rob
    Confirmed tonight that the cable is bound to the steel tube that runs adjacent to the motor. Shot some PB Blaster down the opening at the end of the tube. Hopefully it'll do the trick!
    Quote Originally Posted by 30westrob View Post
    Rob
    Banned
    Nov 2004
    Scottsdale, AZ
    I have the proper NOS cables with correct diameter if you don't want to fight the battle with currently offered cables. Not cheap unless you consider that the current ones don't work well.
Tags for this Thread
