Thread: How does this go in?
    I know it goes through the seal but how does it go into the car? What is its purpose beside holding on to the seal?
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
    The factory has a special tool. I use an awl with washers jammed onto the shaft to equal the depth of the pin. Put it through the seal into the holes on either side of the locating pin then tap in with a hammer on the awl.
    Thanks, will try that
    S Registry #1280
    1970 911T
    1968 911 FWT
    1965 356 SC
