Thread: Original Herbol touch-up paint found!
    May 2013
    Victoria BC Canada
    I was hunting through a box of parts that I put away about 8 years ago and discovered an original can of Herbol code 80 silver paint that is still sealed and liquid!
    I will be carefully trying to open this can so I can get a test sample to match up for my code 80 silver car that will be heading to paint next month.
Size:  39.2 KB Name:  HerbolPaint2.jpg
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Jul 2006
    Switzerland
    Silver (metallic) had a two stage procedure, with a transparent coat applied after.
    Registry member No.773
    May 2013
    Victoria BC Canada
    Quote Originally Posted by 911T1971 View Post
    Yes, the can indicates "for two-layer metallic process"
    Name:  Paint detail.jpg
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '96 S10 truck
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    I assume that the 80 in the metallic vorlack refers to the temperature.. as the baking temperature of the colors had been different.
    http://www.early911sregistry.org/for...138#post986138
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    May 2013
    Victoria BC Canada
    Quote Originally Posted by haul View Post
    That is a great article, thanks for posting the link... Funny the baking temp is also the color code (see top right image, "silber POR 80").
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '96 S10 truck
