Results 1 to 2 of 2
Thread: Steering shaft bearings
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Any chance to replace the upper and lower steering shaft bearings in a MY72 without removing the steering shaft tube?
    Dec 2015
    Bordeaux, France
    You mean not removing the tube from the car? Sadly not, you won't be able to undo the universal joint at the link with the steering rod in the trunk. On the other hand, the top shaft bearing is easy to remove by just removing the steering wheel. This one can get grimy, and cause some problems. Might be a good place to start. If it doesn't help, at least it won't bee too painful.
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
