Results 1 to 10 of 17
Thread: Interior rear view mirror mounting pad
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Bought some rear view mirror mounting pad from Porsch last week.
    They are made by 3M and have two different cover/foil to peel of.
    on the one side is red foil , on the other white cardboard.
    the glue is different.
    which side is for the mirror and which for the windshield?
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by dirk07 View Post
    looks like red foil side goes on the glas
    https://www.youtube.com/watch?v=jQgqXCY-yL0
    Apr 2016
    Stuttgart, Germany
    Thanks a lot, Franz.
    Is it normal that the pad is much smaller than the mirror base?
    May 2013
    AUSTRIA (tu felix)
    depends how you define much...any photographic images available
    Apr 2016
    Stuttgart, Germany
    That’s much
    May 2013
    AUSTRIA (tu felix)
    That’s much
    nope it`s not but i would trim the pad a bit in order to get a consistent" to small" and touch-up the bare metal areas
    The Netherlands
    Hope that there is a black glued surface behind the red...I had one that was white and looked really wrong when mounted.
    Cees
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by fourteenten View Post
    Cees
    the one i got from P was black
    I hope they've improved the glue, couldn't quite stay stuck in the Texas sun.
    May 2013
    AUSTRIA (tu felix)
    Dirk put the sticker on the glass first and then the mirror on the sticker..this way you can avoid visible air boubles
