Results 1 to 10 of 17
Thread: 915 center gate slop
    Jun 2011
    Mound, Louisiana
    1st to 2nd is fine. 3rd takes some practice when rolling though the gears.
    The 3rd - 4rth gate has a lot of side to side slop when engaged. I am thinking something is bent or worn on the inside? As I have replaced all of the soft bushings in the linkage...
    Paul Harrop 12.5% German.
    Early S #2059
    Do you have the original 72 shift housing, or the later 73 style?
    Jun 2011
    Mound, Louisiana
    How do you tell? I almost think it was abused and the rebuilder didn't catch it.
    Early S #2059
    Banned
    Nov 2004
    Scottsdale, AZ
    Paul,
    Is this the same issue?
    http://www.early911sregistry.org/for...565#post989565
    If so, did you re-check the bushings?
    To re-word Ed’s question: Do you have the stamped metal ‘72 shifter base or the ‘73- alum tower style?
    Jun 2011
    Mound, Louisiana
    Paul,
    I'm sorry... I have slept since then and spent many mindless days on my combine....
    So I pull it all apart like you said. Looks okay to me?
    And stamped as you can see. Sorry for my ignorance. I have only driven one other long hood, and that was in the early 80's.
    Thanks Frank!
    Early S #2059
    How about the ring bushing on the shift rod? And BTY you do have the proper 72 style shifter.
    Jan 2011
    DFW TX
    To add my little bit of knowledge as I haven’t experienced the 72 shifter, but I imagine it’s a flipped 901/911. I have been into my 915 a number of times however. There are no lateral stops inside the 915 transmission. The gearbox relies on the shifter to align the 1-2, 3-4 and 5-R gates. Once in gear, there is a fair amount of side to side slop available.
    Quote Originally Posted by M_deJong View Post
    ...There are no lateral stops inside the 915 transmission. The gearbox relies on the shifter to align the 1-2, 3-4 and 5-R gates.
    Mike, there are lateral stops inside the 915 transmission for the 1-2 and 5-R gates (or R gate in a 4-speed).
    The lateral stop for the 1-2 shift is in the guide fork attached to a removable plate on the case, and the lateral stop for the 5-R shift is a recess in the 5-R shift rod.
    I can post photos of the parts I'm referring to if my description isn't clear. You can always see clear evidence of contact on those stops.
    Jon B.
    Vista, CA
    Jun 2011
    Mound, Louisiana
    There are more bushings than in this kit?
    https://www.pelicanparts.com/More_In...SABEgIKb_D_BwE
    Early S #2059
    Jan 2011
    DFW TX
    You are right of course. But 3-4 relies on the shifter.
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
