Thread: Outlet valve Leakage
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Need a decision and a would love to hear some input from the engine guys.
    73E strong driver with a oil leckage.
    We found and repaired the leacking parts ( inner seal of oil inlet of chain case and Sporto oil pump).
    But unfortunately the pressure drop test under warm condition says for cylinder 1,3-6: approximately 0-2% while 2 has 70%.
    Outlet valve is leaking.
    We can’t find the reason with endoscope why 2. cylinder‘s outlet valve blows off.
    It might be some old oil deposite.
    Suggestion how to proceed before we will have to remove the engine.
    Apr 2016
    Stuttgart, Germany
    solved with cleaning, adhesives and autobahn driving.
    too risky to recommend with details
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    What's the difference between heroin addiction & P-Car projects? Heroin use has it's limits.
    Apr 2011
    N.Calif., south of SF
    Dirk07,
    Tell us about the adhesives part.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2016
    Stuttgart, Germany
    Luiqi Moly Ventilsauber
