Thread: TTG Light Install Spacers???
    Feb 2010
    San Francisco, CA
    Quick question, when I last installed a set of Hella 118s I needed to put a stack of thick washers on the mounting bolt to get them spaced in front of the cut horn grilles. Is there supposed to be a spacer in there? If the swivel is right up against the mounting bracket they seem way too close.
    Opinions (informed and uninformed) welcome.
    -Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Dec 2010
    Southold, NY
    When I installed a set of TTG driving lights on an original, no-hit, 1969 Karmann Coupe, one side required a spacer, the other side none, in order to fit properly. Go figure.
    Feb 2010
    San Francisco, CA
    Thanks both!
    Eric, your NOS kits kill me. Any chance you sell the little repop spacer tubes separately?
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2010
    San Francisco, CA
    Much appreciated. I was thinking I’d be able to hot up a hardware store and find something close.
    K
    E911SR & RGRUPPE
    '73 S Coupe #306
