Well, classic for me. Replacing clutch and of course found some other engine projects while it was out. Had belt off alternator and when spinning fan decided it was time to replace bearings. Sev Marchal alternator 71'. Disassembly went fine tiil the end.
1. End bearing is supported by a plastic end cap. Mine is no longer functioning from too many heat cycles and was destroyed when seperated from end cover.
2. Yep, both bearings will need to be replaced. Easily sourced so no worries.
3. Somehow managed to chip one of the brushes on removal, not sure how.
Did some searching and seems that brushes may be secured but no luck on bearing or end cap. Tried a couple of local electrical sources, no luck.
Any ideas for reliable sources for end cap and brushes.
Thanks, Chris
