Thread: Sportomatic 911E 1972 Oil hose lines to regulator housing
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    In the middle of overhauling the oil system, we haven't found a single diagram showing the oil line routing and part numbers for a
    911E 1973 Sportomatic.
    1/6/2 shows both #60 hose line, but only for S/RS.
    What is the correct 911E Sportomatic part number?
    We are also looking for the part number of the hose regulator housing to tank.
    Thanks Dirk
    Apr 2016
    Stuttgart, Germany
    Name:  Sportomatic 73-74.JPG
    Thats a 74 sporto diagramma, which looks pretty close to the reality in my 73E Sportomatic.
Size:  81.1 KBName:  xolC8sDnQgySCynPuDRhmA.jpg
    Can someone confirm that these hoses are also correct for a 73E Sporto?
    Apr 2016
    Stuttgart, Germany
Size:  66.2 KBName:  Ölleitung  (4).jpg
    Hi Dirk
    Not sure if I understand you correctly but the parts numbers for a 73 can be found in this file:
    https://www.porsche.com/all/media/pd...73_KATALOG.pdf
    on page 60.
    Rick
    Apr 2016
    Stuttgart, Germany
    Hi Rick,
    PET only shows 73 S/RS version with thermostat console coupled directly to the oil tank.
    Can't find a single page with 73 E with front cooler and Sportomatic.
    Page 60 shows the oil supply to the Sportomatic converter.
    I need the lines from thermostat to the oil tank and to the engine.
    BR
    Dirk
    Apr 2016
    Stuttgart, Germany
    Finally looks like a previous owner added 74 front cooler, lines and thermostat,or?
