Thread: MFI throttle body stack gasket
    Jun 2010
    Garden State
    Is there any downside to using home cut gaskets between the throttle bodies and stacks?
    The gasket material is thinner than stock measuring .33MM (.013").
    The original used and compressed gaskets measure 1.1MM-
    No, it's just air at that point. The gasket just insures that you are getting filtered air.
    Jun 2010
    Garden State
    Thank you Ed.
