Results 1 to 10 of 14
Thread: Help...How to remove ignition ?
Size:  138.7 KBName:  D1C471D6-8A84-455F-AED4-96AAB5F15CE3.jpg
    I am getting all items rekeyed correctly including cylinders as needed for ignition, doors ,glove box etc.
    Although there is a key in the ignition that fits but does not turn even with moving steering wheel.
    The real questions is how to remove the ignition module or at least the cylinder for new keying.
    Also who has the quickest turn around for keying ?
    I used Tony Eugano for my 356 stuff but that’s been a few years back.
    Noticed that Sierra Madre also provides this service.
    RocketDan has had my set for the 70 for 4 months and infrequently responds to emails. Usually must send via Pelican user name and email to get updates.
    Thanks for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    The remains of one of the 2 shear bolts is in the upper left. When tightening the new shear bolts, the bolt head above the narrow section breaks off. I use a small chisel and hammer and start hitting the remains, unscrewing, counter clockwise. Once it breaks loose it will unscrew. The shear bolts were anti-theft security against ignition removal. Buy new bolts and you will see what the deal is. I think you also drill out the rivets. G
    May 2013
    Victoria BC Canada
    There is also a bolt and nut holding the lock assembly to the column, you can see the nut in the lower image.
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    gled49 and Jones
    Thanks... perfect description of what Is needed
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Aug 2009
    SF Bay Area
    Do your self a favor and just use standard bolts when installing the ign switch. The break off bolts are stupid and only
    Are a nuisance to owners, service persons and old auto dismantlers.
    Jim
    On the bolt holding the lock assly to the steering column, loosen the jam nut and back out the allen bolt only enough to remove the switch assly. If you remove that allen bolt all the way it is a bear to get restarted.
    Glad I held off removing till today and reading of Ed and Jim’s post !
    Great thanks
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Nov 2003
    Santa Monica CA
    that is how I did mine---cut a slot with a sharp chisel and small hammer; then back out the screw with a slotted screwdriver. then reassemble with regular bolt. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Jan 2007
    Phoenix, AZ
    If you have access to a set of Blue Point or SK tornado sockets they make removing shear bolts a non issue. I've done a bunch with the chisel method in the past and that will get it done with some nervousness and frustration.
    NTW
    Please show picture of these as I am not familiar
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
