Greetings Everyone!
I have a 1969 911T. At the moment it has a 2.2T from a 1970. It's a tired old engine that leaks oil, smokes a lot on startup, has always fouled plugs, and has uniform, but low compression (roughly 90PSI all around warm).
I've been dreaming of a better motor for a long time, and was shocked when two amazing things happened at once yesterday: I found a 2.4E longblock in the classifieds, and my wife gave me permission to buy it! I'm super excited about the higher redline, extra compression, greater torque, and having a more robust platform for future building should I want to go up to 2.7 or other future dreams... http://www.early911sregistry.org/for...-911-52-Engine
I have some of the more common reliability mods on my old 2.2 that I plan to transfer over. I have a set of SSIs, pressure fed Carrera tensioners, and a 75amp alternator. I plan to move all that stuff to the 2.4E. Will the SSIs still fit? When was the change between thin and thick exhaust flanges?
I have relatively fresh set of Zenith 40TINs that I plan to use for fuel, they have the stock 27.5mm vents, but I have a set of 30mm vents and some alternate jets. Someday when I have the cash I'll either home cook some EFI or I'll prowl the classifieds for MFI. For now, does anybody know a good starting point for 2.4E Zenith jetting?
I know there are some differences between the original 2.0, the current 2.2 and new 2.4. The biggest problem I see immediately is the clutch - the 901/13 transmission I have only supports a push type pressure plate, but the 2.2 and 2.4 used the 215mm, pull type pressure plate. I got around this with my 2.2 by just using my old 2.0 flywheel. Is that still an option? Can a 2.0T clutch handle 2.4E power? Is there a way to get the larger clutch to work with the right type of pressure plate?
Another concern is oil plumbing. My 2.2 didn't seem to need anything special when I put it in, but I've read about special oil lines being required for some engine conversions - is the oil plumbing between the 2.2 and 2.4 the same?
I know that asking this question is like throwing a grenade in the room... but ignition... (sigh) the factory used a 3 pin CDI, but my poor '69T did not come with on of those. I had an MSD 6AL for 12 years, but it kept melting rotors and finally started blowing them apart, then it failed completely. I'm reluctant to go with another MSD... I also simply don't have the cash for a Bosch CDI. What sub $300 systems are people having success with?
The 2.4 came with the full cooling system and a distributor. I'll probably just clean that up an use it unless I find any problems.
Any other pitfalls when installing the 2.4/2.7 case into a '69 body? I'm trying to get whatever parts I can prior to returning home.
I promise lots of pictures once I start the project! Right now I'm at sea aboard USS IWO JIMA, on my way home from Iceland and Norway, but I'm really looking forward to my Christmas leave project! I'm so thrilled about this dumb motor I've barely been able to sleep!
Thanks!
-Dan
