Results 1 to 2 of 2
Thread: FS: 2.2 liter Ps and Cs
    Dec 2009
    Copenhagen, Denmark
    For sale is one used full set of 6 1969-1971 Porsche 911 T 2.2 liter 84MM pistons and cylinders with new piston Rings. They were measured and found to be within spec. Last used in January 2018. They have been in protected storage, have a thin coat of oil for protection and show no signs of damage, are measured within spec and used. The cylinders are the standard (for 911T) cast iron Kolben-Schmidt; the pistons are standard Mahle (84mm). The pictures speak for themselves. Very high quality, just plug and play. Minor discoloration and surface rust on cylinder fins only.
    $500
    James Hurst #1638
    R Gruppe #514
    Dec 2009
    Copenhagen, Denmark
    sold for $450.
    James Hurst #1638
    R Gruppe #514
