Results 1 to 2 of 2
Thread: Brake line swap question - 1968
    Hello all. I am the new owner of a 1968 911 that has been sitting for many years. My first project is to refresh the brakes, followed by the tires. I bought new lines, hoses, master cylinder, rotors, pads, and rebuilt calipers.
    I bought Stainless Steel braided brake lines, which come all 4, 2 long and 2 short. The 2 long ones have female fittings at both ends, which match up with the old rubber ones I took off the rear, except they are a little longer than the rubber ones, maybe a couple inches. The result is that they make a rather pronounced S- curve between the hard lines. Is this right? I actually have 2 sets, as I bought one for my 912 as well, and the are the same way.
    The fronts, I presume are the shorter ones, and have males and one end and females on the other.
    I have looked around here and on Pelican, but can’t find any SWB specific (or 1968) info. Thanks.
    I can't tell what you have length wise, but compare to your old ones,,,,,the rear should be the shorter one. Actually the fronts make a bit of an 'S' curve around the strut.
