Thread: help ID forward engine shroud pieces
    Mar 2004
    Castro Valley, Ca.
    neither my '72-'73 parts manual nor the PET make it clear what years these pieces are for.
    input appreciated.
    TIA
    1940 Mercury town sedan
    I'm pretty sure the back piece (next to the cooler) didn't have that wiring harness notch until 1970. The piece for the other side is probably 68 and up, since that was when the sportomatic started and would need that opening for the sporto pump.
    Mar 2004
    Castro Valley, Ca.
    thanks guys. one more to add. I presume this is for early carb cars ?
    That is to cover the pulleys and belt of a MFI car
    Quote Originally Posted by typ901 View Post
    As Sanders said, that's the LH cover piece for an MFI engine. It should attach to the other LH piece in your first photos. Do the three screw holes line up on both pieces?
    Jon B.
    Vista, CA
    Mar 2004
    Castro Valley, Ca.
    bingo!
    thanks again to all.
