Results 1 to 8 of 8
Thread: What color black?
    Dec 2013
    Connecticut/Florida
    What color black?
    I am refinishing the tops to the stacks (some folks call them Boats?). The steel units with the metal clips, Is this just a flat black? Any special paint issues to be worried about? (ones above are NOT mine)
    Name:  Screen Shot 2018-12-18 at 10.21.43 AM.jpg
    1971 911S Coupe - Gemini Blue
    I believe they were the same (approx.) 60% semi gloss as the rest of the engine tin... The factory used oven baked enamel... most today powder coat them... take care of the internal cold start system in there...
    Dec 2013
    Connecticut/Florida
    Thanks Chuck...so there was an internal cold start system? my 72T had an external system, but I don't see any system on the 71S
    Yep... The 2.4S/RS plastic stack/plastic air cleaner systems had external… The cast stacks and metal air cleaners had internal...
    cm
    Dec 2013
    Connecticut/Florida
    cm
    Thanks. So I do have the corrrect metal air cleaner for my 71S that has the cold start lines within the air cleaner.
    Yes...…
    Good luck on your project.....
    There has been a lot of talk about air cleaner housings used over the years and 1971 is a bit tricky.
    At some point in MY 1971 the plastic air cleaner housing was introduced (which looked and performed much like the previous metal version).
    See post #9 from Grady Clay in the following thread which addresses the housings used in various years:
    http://www.early911sregistry.org/for...ious-MFI-years
    Thats right nick... (I even contributed to that thread) Yeah, in '71 I think they were metal 'buckets' w/squirters, under a plastic cleaner housing....
