Results 1 to 10 of 10
Thread: Engine lid cable guide
    Dec 2011
    South West of UK
    Can someone post some photos of how the 8mm guide tube for the lid opener passes from the B post through the rear arch and ot to the rear crossmember. My tube is missing and I am looking to fit a new one. My rear cross member was replaced in the past and there appears to be no hole from the engine bay out to the wheel acrch area. There is a loop on the inside face of the cross member for the end of the tube. I assume I tag weld the tube.
    Dec 2011
    South West of UK
Size:  48.1 KBName:  6FB22EB4-F520-4F7E-9427-F76FF1F6F67D.jpeg
    Dec 2011
    South West of UK
    I found a hole. Covered over with compound and paint. I assume this is where the tube comes through., sorted unless I am mistaken.
    May 2013
    Victoria BC Canada
    There is a tube that runs almost to the latch from the hole you found. When I visit my car in the paint shop in a couple days, I'll take a picture and post it for you.
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Michael,
    that is exactly the hole, where the engine lid cable guide runs through.
    I bought this guide some weeks ago. Still have to build in.
    seller was: https://www.ebay.de/itm/Motorhaubenz...72.m2749.l2649
    Dec 2011
    South West of UK
    Thanks that is excellent. I have some 8mm OD stainless steel tube from eBay. It was 2m long and a fraction of the price of the OEM part. Now I just need to bend and fit it.
    Apr 2016
    Stuttgart, Germany
    lid cable guide
    hole
    that's how it should look like-rust included
    May 2006
    CT
    Here are some photos of the engine lid cable guide path from my '70E
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2015
    Bordeaux, France
    Now to get a really good look at where the guide tube goes, you have to remove the rear fender. Pardon my rust, this is a while ago just after media blasting. ;-)
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
    Dec 2011
    South West of UK
    Thanks for the photos. These are a real help. Just finished fitting and the stainless tubes I got worked out fine. I formed the bell ends with a brake pipe tool and used an 8mm external pipe spring to do the bends. I thought this may be difficult but they bent fine without creasing or kinking at all.
    The cable I have is supposed to be the right length but is about 2” short. I thought this was because the pipe was too long. It’s should be 1750 long according to what I have seen on line but could not get my tube that short. I followed the path shown as best I could whilst keeping the pipe as short as I could. Seeing the above photo I am sure it must be longer that that so my cable must be short. It was a used part from eBay so it had probably been cut in the past. I will get a new one in.
