Results 1 to 7 of 7
Thread: Blaupunk New Yorker
    Blaupunk New Yorker - SOLD
    SOLD
    I have this New Yorker for sale. Z code, so correct for 1967/8 I believe.
    I have no way of knowing if it works or if it is complete. It looks good.
    The New Yorker was the top of the line Blaupunkt in the late 60s, it has an autoseek function.
    SOLD AS IS.
    SOLD!
    Henry
    Jul 2011
    Chicago Area
    Interesting wiring harness. Is that original?
    Mike Fitton # 2071
    2018 911S Carrera White
    Without the power pack the radio will not work
    Quote Originally Posted by mfitton View Post
    No idea, I guess part of it could be, but the other end does look as if it has been cut at some point.
    Henry
    Quote Originally Posted by enoz05 View Post
    I clearly stated I don't know if it works or not, and I didn't know it required a power pack (I have a Z Frankfurt that works without a power pack). These sell for over $1,000 dollars when operational and in good shape.
    https://www.chromelondon.com/blaupun...db5-2892-p.asp
    Henry
    [QUOTE=hdavis;1000303]I clearly stated I don't know if it works or not, and I didn't know it required a power pack (I have a Z Frankfurt that works without a power pack). These sell for over $1,000 dollars when operational and in good shape.
    A Blaupunkt Frankfurt doesn't need a powerpack, but a Blaupunkt NewYorker does. So your radio will never work without it.
    Jul 2011
    Chicago Area
    [QUOTE=enoz05;1000304]
    Quote Originally Posted by hdavis View Post
    Ok, so all those frayed wires used to be for a single DIN plug that connected to the power pack? The power pack has the speaker plug holes also. The link you provided to chromelondon.com clearly shows the power amp that is needed.
    Mike Fitton # 2071
