Thread: Clutch cable - grease/no grease??
    As a follow up to my throttle rod/bushing grease question, I would appreciate thoughts on the same for the clutch cable. Here again, all the cables I've seen or taken off has a liberal application of what appears to be a wheel bearing type of grease that lubricates the steel cable inside the white plastic tube it runs through. Since I'm installing a new one that is clean, checking on thoughts as to the need, and if so, traditional grease - or a white grease as Ed mentioned he uses on the throttle rod/bushing interface. Thank you!
    Bump for opinions please...thank you.
    Quote Originally Posted by mac73s View Post
    SWEPCO 101 Moly.....great stuff for cables. linkage, wheel bearings. Used it for years without issues. ("White grease," Lubriplate is too light for cables)
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    I'm with Mark
    Thank you guys....I appreciate the responses.
