Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Spacer size with 7R?
    I'm going to run 7R wheels with 185/70 Pirellis at all 4 corners of my non-flared car.
    What size spacers should I use?
    Early S Registry #913
    On a LWB car, 7mm minimum to clear on the inside. Not sure if non-flared is SWB.
    thanks, I have a LWB.
    I have always used a factory Turbo 21mm hubcentric spacer on the rear.
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    7R on all four corners?
    www.tcspeed.com
    I ran 7R's on all for corners with 205/60's on my 73. + factory 7mm spacers, and 68 or RS wheel studs that are 10mm longer than stock for 20 years or so before refinishing and selling them. It was my choice to minimize spacers.
    Would like to see a photo if you have one.
    Thanks.
    Early S Registry #235
    rgruppe #111
    Can't find it now but they are the stamped perforated ones. G
    A picture of the car.
    rgruppe #111
    7r
    I can only speak for the rear. The factory spec required 21 mm spacers when using the 7R wheels ("... müssen 21 mm dicke Distanzringe verwendet werden"). Longer wheel studs (72 mm) also required. On my 1970 2.2S it looks like this.
