Thread: MFI cross bars
    MFI cross bars
    69-73 MFI replated cross throttle bars.
    $85 each plus shipping
    Please email.direct to : rcabell911@gmail.com
    Rick, I think those are all pre 72. Go
    Thanks for watchin my back G.
    I thought there might be a difference between the plastic stack, and the mag stack cross bars. So I checked parts #'s on PET for a 69/70, and then for a 72 and the part number was the same. If PET is wrong, (which it can be), please point it out so I know.
    Senior Member prez!'s Avatar
    May 2010
    Atlanta GA
    All three are 69-71.
    R Gruppe #631
    Early 911S Registry #1825
    1973E Coupe
    Pix is of the 72/73 cross shaft, with "V" at the pull rod ball end/pump rod ball end. The engine has late throttles with 70 Mag stacks. Matt at Eurometrix says cross shafts and pull rod should be matched because of different lengths, otherwise they can be interchanged. The 69-71 cross shaft is closed at the pull/pump ball end location. G
    Good info guys. OK, now everyone knows exactly what I am offering.
