Results 1 to 10 of 12
Thread: 2.0 S 1969 euro car
    Nov 2018
    Malta
    2.0 S 1969 euro car
    Hello all
    am also seeing this girl and would like to know from you if at first glance all seems correct
    it is claimed to be an all matching vehicle constructed for the European market.
Size:  62.0 KBName:  081051091113760.jpg
Size:  67.7 KBName:  081051091116972.jpg
Size:  44.4 KBName:  IMG_9925.JPG
Size:  69.8 KBName:  081051091114551.jpg
Size:  35.1 KBName:  081051091115616.jpg
Size:  35.5 KBName:  IMG_9937.JPG
Size:  72.9 KBName:  IMG_9935.JPG
Size:  36.3 KBName:  IMG_9932.JPG
Size:  113.0 KBName:  IMG_9929.JPG
    Nov 2010
    Darien, CT
    Didn't you check this one out back in November?
    http://www.early911sregistry.org/for...ight=119301056
    69 911S #1379
    65 356 SC #130757
    Chassis and engine numbers are correct range for a 69S
    It has the correct '69 one-year-only two-solenoid MFI pump
    Exterior door handles also correct ('69 is the only LWB to have these, changed in '70)
    Think the seat hinges are wrong?
    Can't see the headlights. A very common restoration error is to replace these with H4s (should be H1s for a Euro car).
    And various cosmetics not 100% per original, but that's not surprising given that it's clearly a restored car.
    '69 S RHD / '70 S RHD resto / '65 mild resto
    www.safetycolours.com
    Nov 2018
    Malta
    Quote Originally Posted by Scott72 View Post
    negotiations getting closer ;-)
    Nov 2018
    Malta
    Quote Originally Posted by inaglasshouse View Post
    Thank you , this is best I can show you for headlight Name:  081051091109497 (2).jpg
    Quote Originally Posted by Bowzer View Post
    Thanks. Pretty sure that is an H1 (so broadly correct, although as usual there is some devil in the detail!)
    Nov 2018
    Malta
    Thank you so much inaglasshouse
    VIN = 119301056
    Eng# = 6391482
    Trans# = ?
    Prod# = ?
    Feb 2005
    Lake Tapps, WA
    I own #119301050 so one could assume they were on the assembly line at the same time. Car looks great BTW, good luck with your potential purchase! A little over restored in some areas but looks to be easily rectified if you wish. Things I notice are the white trunk sheet metal...should be painted over with satin black. And the rear quarter window vinyl trim has padding under the vinyl...it should be vinyl directly over the metal base.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Nov 2018
    Malta
    Thank you Endo
