Results 1 to 8 of 8
Thread: Any experinces there with rebore alusil cylinders and replate them?
    Nov 2014
    Finland, Kuopio
    Have anyone done it ?
    I try to search writings about it from forum source but none found
    my idea is to use 90mm KS alusil cylinder, to overbore to 92mm and sent to replating them with nicasil (or similar)
    Any experiences and comments based on that there, good, bad not dooable at all?
    also how thick (to undersize the bore) spray have been done, ,25 or ,50mm or less
    Would like to hear if experiences exsist as replating cost and if thy come as crap out not funny for wallet
    thanks in advance
    pekka
    911 S -72 Targa
    911 S/T -70 Gulf- replica
    930 -88 Coupe no sunroof, mint
    911 S -75 Targa /cabriolet
    911 T -71 Targa project
    911 T -70 Targa project
    928 S4 with XX8 option -91
    "Super" -59 Schlepper
    +some water cooled 924&928&944&968&958&997series
    Sold and gone only to remember
    911 2.9 RC -70, 911 3.2 cab -89, 911 T -70, 928 S4 -90, 944 -84, 911 T-71, 356 B -60, 911 -65, 986 3,2S -01, 955 3,2 -04, 957tbo -08
    Early S Registry # 3253
    PCF # 710
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    These guys may be of help with coatings. cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    May 2006
    CT
    It is a standard practice on the 95 mm cylinders to overbore and re-plate in Nikasil to 98 mm. The 2.7 should be no different.
    I have used Millenium Technologies for this.
    https://www.millennium-tech.net/
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Nov 2014
    Finland, Kuopio
    Thanks for the reply
    just to understand right so you do also that for kolbenschidd alusil cyls?
    Mahles I know they work nice for replating but they are diffrent combination of metal the liner part
    sorry to replicate my question, but better to ask than thought
    911 S -72 Targa
    PCF # 710
    May 2006
    CT
    Yes. Common practice is to take 95 mm KS Alusil cylinders and bore and re-plate them to 98 mm Nikasil.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Early S Registry #235
    rgruppe #111
    Nov 2014
    Finland, Kuopio
    Thanks for the forum,
    Ikeep posted how they come when I got them back, so standart steel piston rings, not any cromal or otherwise treated
    I´ll send cyls&pistons to France, to Revaltech they have done me one se for my turbo(mahles) and the outcome and details were exelent
    911 S -72 Targa
    PCF # 710
    I worked with a local local high performance engine building machine shop a number of years ago and what we came up with, was doing, was acid etching the surface of the alusil cyl, this allowed the silcone bits to float to the surface. We tried this because he used to do a lot of work on the old Vega engines that were almost identical to Porsche cylinders. They were an aluminum blocks where the pistons ran without liners. Did quite a few engines like that and don't remember any of them coming back ( those things , you don't forget ) He is still doing that today and has done a lot of cyl this way without any issues with ring seating / oil consumption
    Don't know if this helps
    Thanks, Rick
