Thread: MFI throttle housing, stavk and air horns for 2.2 911E
    Price reduced to $1250
    I serviced this single throttle housing, stack & air horns as a display piece. It is 100% refurbished & restored with re-bushed shaft bearings (through the casting & not just the outer partial bushing like is typically performed); re-sized throttle bores and custom fitted throttle valves. Linkage is adjusted but not bench flowed as this was not important to me as a display set. This is a single body only & is ready to run. $2200.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    MFI throttle housing, stack and air horns for 2.2E - Price reduced
    Price reduced to $1250.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Stack no longer available.
    Paul Abbott
    Early S Member #18
    530.520.5816
