Results 1 to 10 of 17
Thread: Weld in exhaust pipes
    Finally up to the exhaust on my 7 years ST project car
    Have a sports muffler with 2 side pipes which we will remove and I need to find a supplier for some new 70mm diameter weld in pipes
    which will come out of the muffler to match the cut outs under the rear overiders, as can be seen in the pic.
    Hopefully with some baffling inside them like I have seen on many sports purpose builds on these pages otherwise I fear it may be too loud
    Any clues please???
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Restoration newbie.
    Jun 2007
    San Francisco
    Does this help Clyde?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Thanks Andy yes that is what I will have but what I was asking is where can I buy the two new tail pipes to weld into place.
    Clyde Boyer
    Oct 2010
    Sweden
    Quote Originally Posted by BOYER73S View Post
    I have seen that protective tubes for front shock absorbers are used for this
    Light Yellow -74
    @lagteknik
    Junior Member
    Apr 2013
    Stuttgart / Germany
    Hi Clyde,
    how loud is ok for you.
    At Eisenmann Exhaust Systems in germany they can deliver die RSR muffler in 4 types.
    78 db, 85 db, 98 db, 105db.
    Do you have the openings in the stock position?
    The 78 db is street legal in germany, the 85 db is great on the road. If you choose the 98 db it`s loud for a street car, but some guys drive it like this on german streets. Eisenmann Exhaust Systems delivers the muffler in the stock Porsche configuration for example to the Porsche museum itself. In america you could buy the muffler from IND.
    BR Jürgen
    www.frisiersalon-nowak.de
    Hi Jurgen
    Not too loud if possible we have 75 db as a street standard.
    All good info but I have a danks sports exhaust already with the 2 out pipes, which we plan to remove and I am looking ONLY for the
    pipes to weld into the centre part of the muffler, not a whole new muffler.
    Clyde Boyer
    When I made my 'R' type muffler to exit under the bumper guard cut-out I just went to a local muffler shop and got a couple pieces of 2 1/2" pipe. I did have to cut holes in the end baffles to get a better opening to the new outlets.
    Here is the real deal. Inlets and exhaust tips actually line up and with baffles in tips it's not to loud. G
    Very stunning!
    Gordon,
    Is that the Dansk replica or a real one from a stash? Do you recall the center to center spacing on the pipes?
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
