Thread: Deep six wheel question
    Senior Member zenithblue71T's Avatar
    Dec 2009
    Copenhagen, Denmark
    Is this a correct statement guys?
    “ the Deep 6″ Fuchs ended in year 70 with hearts and later Deep 6″ without hearts by late 1970 early 71
    The Flat 6″ Started in early 1971. I think around March/ April of 71
    The early Flat 6″ take 3 prong center caps like these here and the later Flat 6″ in late 1973 went to a pop in larger mm collar type cap
    You also can tell by the Porsche Part starting wtih # 901 …. would be for the Deep wheels and 911……. part # for the Flat 6″
    James Hurst #1638
    R Gruppe #514
    911T with 2.2S Ps and Cs, Solex grind Cams and PMO 40mm
    Not sure about the details you have summarized but my set is #901 361 012 dated 71 .
    I will check but believe mine have hearts.
    Interested in additional comments and info as well
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Dec 2009
    Copenhagen, Denmark
    This statement was not mine and was from an ad on BaT.
    James Hurst #1638
    R Gruppe #514
    James
    There are some good points from several posts in the Tech titled
    “ Is there a tutorial on Fuch’s “
    Harvey has a great summary
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Sep 2007
    Norway
    This info sounds correct. I can not remember the exact months when changes occured.
    Did actually the changes from deep6 to flat6 happend when the new 2.4 in august '71 came and did the change to collar type cap happend when the G 911 came in august '73?
    '67 911S Sunroof, Polo Red(Project disguised as a G-model)
    '67 912 Sunroof, Light Ivory(Alive and kickin')
    '67 912 SWTarga, Signal Red(Project in the making)
    X: 67 911 Coupe + 67S Targa, 912, 924, 944, 928, 356
    Feb 2003
    In a nutshell, yes - the details you mention are what I understand to be correct.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
