Thread: correct seatbelt door panel for 1973 S
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    My car came with two different rear interior panels: Which is the correct one? The one on top has had some box (?) attached to it, but isn't present now. "Elephant" grain seems different as well.
    Thnx for any "period-correct" info.
    911S 1973
    Early 911S Registry #176
    The 72 U.S. cars had the add on box for the retractor. I think 73 may have also used that one. Probably 74 and later the 'box' was built in .
    The Netherlands
    For a Coupe the top one is correct, you can still see then indent of the seat belt cover. The bottom one is post 73.
    Groeten, Cees
    Jan 2003
    The Netherlands
    Dank Cees! Are these boxes/covers hard to find?
    911S 1973
    The Netherlands
    Yes unfortunately. Repro's are available though. Eckert I believe and CarPoint.
    Cees
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    I‘ve two or three pairs left. Last set 72/73 reels left.
