As I'm selling my car: 2.5 ST with a twin plug ( 2492cc ) engine, I don't need this 2341cc engine that was built as a spare for road and rally.
73 T magnesium 4R Crankcase
Oil bypass mods & "big" (3.0L) oïl pump
Mahle NOS 2.2 S Cylinders ( mooned) and Pistons ( High Dome)
Compression ratio : 10.3 :1
70.4 crankshaft balanced with flywheel and clutch
lightweight rods
Mod S camshafts
Zenith carbs specially tuned and jetted ( 34 primary venturi )
Dyno Test results after 700 km on the road ( between 2750 & 5750 rpm )
- TORQUE : 271 Nm @ 5500 rpm , 230 Nm @ 2750 rpm
- POWER : 169,9 KW @ 6250 rpm , 156,3 @ 5500 rpm
photos of the engine and copies of Dyno tests available on request at : jean-Dominique.julia@Wanadoo.fr
28500 $ or 25000 € plus crating and shipping costs
