Results 1 to 10 of 12
Thread: FS: '65-'68 911 Seat Belt Hook Assemblies, 901.803.135.00
    These components replace the NLA TEKA, American Safety Equipment (ASE) and Hickok 3-point seat belt hook assemblies. They have no part number, but are similar to the LWB version:
    PET 70-73 911 Fig 8-12-00, #14 901.803.135.00 Suspension hook Qty: 2
    Material: Polyurethane
    Finish: Ra 12µm (As molded)
    Weight: 1.68 grams
    They come with upgraded stainless steel sheet metal screws:
    PET 70-73 911 Fig 8-12-00, #13 900.143.004.00 Oval-head sheetmetal screw, 3,5x19, Coupe Qty: 2
    The price is $9.37 each or $18.74 per set of 2 hooks and 2 screws.
    USPS Parcel Post shipping in the US is $4.50.
    Special thanks to Mark Allen of Vintage Excellence who provided the original parts.
    Other available parts:
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Always amazing parts. Thank you for the bezel recently received. Cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Nov 2010
    Harleysville, PA
    Pm sent.
    Mark
    1967 911S - 306465
    1980 911SC
    2005 Carrera Cabriolet
    I'm interested in a pair of these but can't PM you for some reason. Would you mind getting in touch?
    Cheers.
    Hello,
    I would like to buy a set of the 65-'68 911 Seat Belt Hook Assemblies if they are still available. Please let me know how I can send the payment.
    Thanks very much.
    Best,
    Michael
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Jimmy,
    will these fit the Teka belt?
    br
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Teka Seat Belts
    This info might help JimmyT with the Teka questtion.
    Attached Files Attached Files
    Bob
    Early S Reg #370
    Both the SWB and LWB shoulder belt hooks will fit in the 12mm hole in the Teka seat belt tongue. Since it was designed for the Teka belt, the SWB hook fits perfectly. Although designed for the REPA belt, the LWB hook holds the Teka belt tongue, but doesn't let the tongue rotate down to hang vertically on the hook's shaft.
    Quote Originally Posted by haul View Post
    Jimmy,
    br
    haul
    Jul 2014
    bavaria
    just went to my car just to check the eye of my teka belt…its only 11mm, and the widest part of my old hook is at 13mm
    see attached…
    erwin_loves_polo
    In 4mm thick sheet metal, the smallest hole that a SWB hook will pass through is 10.35mm ID.
