Results 1 to 1 of 1
Thread: Set of Weber carbs & manifolds for 1968 911S by Performance Oriented
    Just finished remanufacturing a set of Weber IDS carbs for 1968 911S. $10,500
    Details:
    • Fully blueprinted and restored including fuel gallery plug & stud removal
    • Corrosion free throttle bodies and manifolds selected as cores for the restoration
    • Six sintered bronze throttle shaft bushings installed per carb
    • Throttle bores re-sized and custom sized throttle valves installed
    • New long throttle shafts
    • NOS short throttle shafts
    • OEM venturis
    • Jetted for 2.0 911S
    • Test run and all adjustable features tuned
    • Throttle bodies refinished with period correct alodine finish
    • Steel hardware restored (zinc plated with yellow chromate finish)
    • Accelerator linkage bits are nickel plated
    • Intake air horns are OEM, period correct and nickel plated
    • Intake manifolds are 911S; one is dated 1968 and the other is 1970 (matching casting details)
    • Manifolds decked, refinished in black chromate, studs & shaft removed & refinished
    • Air horn washers are the unusual brass type used to guide socket during tightening
    • New fuel floats
    More photos and construction details are available upon request.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
