Performance Oriented remanufactured this single throttle housing, stack & air horns as a display piece. It is 100% refurbished & restored with re-bushed shaft bearings (through the casting & not just the outer partial bushing like is typically performed); re-sized throttle bores and custom fitted throttle valves. Linkage is adjusted but not bench flowed as this was not important to me as a display set. This is a single body only & is ready to run. Price: $1250
