Thread: 10K tach 60,000 Imp
    10K tach 60,000 Imp
    I bought an Ashlock tach tester amd hooked it up to my 10K tach with 60,000 Imp markings. Not for a 12 cylinder as thought but worked pefectly as a 6 cylinder tach right up to the 10K limit of the tester and worked on low voltage signal like pre mid-70 tachs. It has no part nr., original for 911R? The converted 10K tachs I tested worked on high voltage signal and the needles dropped before 10K was reached. That tester was well worth the money.
    Jul 2011
    Chicago Area
    I have never seen an imp marking in ink before and the "6" looks a little funny, anyone else see one like this before?
    Mike Fitton # 2071
    2018 911S Carrera White
    Apr 2004
    35,000 ft
    Standard 8k tachs were 24000 imp...standard 6cyl 10k tachs were 30000 imp....always punched in the housings, I’ve never seen them in ink. Maybe it’s for a 2-stroke, 6 cyl, 10k motor
    Feb 2012
    Sweden
    No article number on the inside "ring"?
    -70 911E
    -84 3,2 Sold
    Sep 2009
    UK
    Any date on the side of the can.? As mentioned, any part number under the trim ring above the number 5. ?
    VDO made in Germany is the only engraved marking on the can. No part nr. on the inner ring top, 0020 on the bottom of the ring. Tests correct for 4 stroke 6 cyl. single spark low voltage impulse and actually registers 10K rpm unlike the pretenders. The 6 and maybe the first 0 look hand written. I thought it could be for a 12 cyl. motor until I tested it. I saw one VDO 10K tach that was modified to 60,000 Imp for a Jaguar 12 cyl. race car in my research but that was the only other 60,000 Imp reference I could find.
