Thread: 1972T to ST conversion. Rear banana arm options?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    i have a 1972T currently converted to RS with 1984 Carrera rear banana arms.
    For a RSR or ST conversion, what would be best used for banana arms? stock? 930? etc?
    www.tcspeed.com
    ST wouldn’t of had short training arms like a RSR. 930 would locate like RSR. The trouble with 930 is wheel flange is too far outboard, not like RSR. Stick with your Carrera arms for your ST. G
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    I used aluminum trailing arms from a middie, 74’ if I recall correctly. Direct fit on my 72T ST build.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Jul 2006
    Corvallis, OR
    If you want to use the stock rear sway bar attachment location then you'll need early aluminum TA's. The 1975 18mm Carrera rear sway bar is a nice set up for the early cars with an 18mm in front. -Scott
    72S, 72T now ST
