Who makes the best fitting seals for the targa roof, looking for both left and right sides. My car is a '71 and part #'s are 911.565.260.40 (R) and 911.565.259.40 (L).
Mike Fitton # 2071
2018 911S Carrera White
These are still available as Porsche OEM units which are really the best ones to use.
$400.00 for the pair plus shipping
Let me know if I can be of help.
Erik - (303) 443-1343 ext. 2
Carquip
Thanks Erik, just ordered the genuine Porsche ones.
Mike Fitton # 2071
Mike,
Make sure the packages are sealed, when you pick them up. I ordered a set from Porsche and when they arrived one package was opened. Didn’t get around to installing them for a month and when I did, I found that one was a URO seal. Someone returned it to the dealer and I got stuck with the ill fitting piece of crap. Too late to return.
Tony
'68 912 SWT White
'74 911 Targa Lime Green
'03 Boxster S
‘13 Cayenne GTS
It will be interesting to see how they fit. From my experience a few years back, they must be modified to fit the early Targas.
Mike Fitton # 2071
I can second Tony's warning in post #4 above. It is as if some people are "scamming" Porsche parts departments by substituting aftermarket seals into packaging from Porsche originals. Your local parts agents then hand the packages to you unknowing. This has happened to me several times, but because I'm on to it, we reject the part and start over again. Unfortunately, the part and package just goes back to the warehouse and is probably foisted on some other unsuspecting dealer/customer combination. I'm not suggesting this is widespread. But it is worth being suspicious when you order, for example, right and left side seals and one arrives in an unopened, sealed factory package, and the other is in a different size bag with a replacement label closed with a piece of clear plastic tape.
Got my seals today, packaging looks unaltered with Porsche labels dated May 2011 & June 2012.
Mike Fitton # 2071
