Results 1 to 10 of 11
Thread: WTB: ignition lock metal cover
    Nov 2016
    Munich, Germany
    I am looking for the metal cover of the ignition lock. That is only the cover that goes on the screw-on bezel, not the bezel itself. Some PO got rid of mine.
    If someone has a nice little patinated one - preferably not at all concourse - somewhere on his attic I'd appreciate a short reply.
    Please also reply if it is with the bezel. Then I will rip it apart by myself to have it without the bezel ;-)
    Nov 2016
    Munich, Germany
    Servus Franz!
    Car is 10-12/69 = MY70. But what do you mean by "ID"?
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by tomster View Post
    Servus Franz!
    inside diameter .....diameter of the hole
    Nov 2016
    Munich, Germany
    I will get my "Geodreieck" out tomorrow and measure it.
    As much as I found out there should be only 2 IDs:
    '66-'69 13mm
    '70-'73 18.7mm
    is this correct? I'd say from memory mine is more like 18.7mm.
    May 2013
    AUSTRIA (tu felix)
    ausgezeichnet aber nicht das löchli im plastik messen sondern den AD am schlüsselreinsteckblendchen am schloss...eine schiebelehre aka messschieber wär da geeigneter i`d say....und ein bild würd auch helfen
    Nov 2016
    Munich, Germany
    Eh kloa! Des war bloß a Schbass mim Geodreieck.
    Pic and dimensions will follow tomorrow.
    Aug 2011
    Eugene, OR
    I have one from my early '72, somewhat patina'd. I'd planned on refurbishing it to put it back on the car when I get to redoing the interior, but am open to offers.
    - Arne
    Nov 2016
    Munich, Germany
    Here's a picture of the ignition lock. The cap is 16.4mm/ .645" in diameter.
    I just saw there is an aftermarket replacement available. Dunno if the cover is metal though. Looks a bit more like plastic on the pics:
    https://www.partworks.de/partworks-d...ndschloss.html
    Thx Arne. I'll give it a thought. No clue what that cover could go for...
    Aug 2011
    Eugene, OR
    But note that the center hole in mine is just under 19mm. Doesn't appear to be the one you need.
    - Arne
