Results 1 to 1 of 1
Thread: FS: Porsche 356B engine 1960 #600416 Built July 1959
    Includes matched 3 piece case, crank, rods, pistons, cylinders, cam, cam followers, fuel pump, oil cooler, flywheel and front pulley. No heads. Turns over fine and cylinder bores look OK as do the pistons. Taken apart decades ago for a valve job before the heads disappeared. Part of a 50 year accumulation of 356 parts that I recently acquired. All of the parts were properly stored in a dry garage.
    Could be shipped UPS but I would recommend freight or local pick-up.
    $3185
