Thread: Targa window scrapers
    I've used the search function to no avail.
    Does anybody have a picture of the correct way of mounting the targa window scrapers?
    Straight edge goes against the quarter window but how far do they go on the edge where the
    trim piece meets the window guide rail?
    Thanks in advance!
    Kind Regards,
    Johan
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    What's the difference between heroin addiction & P-Car projects? Heroin use has it's limits.
    Looking at it a bit more, I think it fits better with the straight edge against the edge of the door
    and the other side against the quarter window.
    Anybody? Would like to drive the car tomorrow.
    Thanks in advance!
    Kind Regards,
    Johan
    Not sure I know what you mean ???? If you mean the rubber that slides into the chrome trim piece that attaches to the top of the door, then you just cut the rubber to length at an angle to match the vent window frame.
    Thanks Ed,
    Indeed the rubber that slides into the chrome trim piece,
    if you buy the rubbers from Porsche, it comes with one side angled and the other straight.
    Just wanted to be sure the angled side is at the vent window frame and the straight edge on the side of the window edge.
