Results 1 to 9 of 9
Thread: Engine: 911523 901/05 or 901/06
    Senior Member softwindow's Avatar
    Jan 2015
    Bonn, Germany
    Hallo experts,
    my car does not have the original engine. Kardex shows the original number is 911523. Is it right that this is an aluminium engine type 901/06?
    Or could it also be a 901/05?
    I want to choose the right period correct engine.
    Thank you for your help.
    Kind regards.
    Bernd
    356 A 58 silver
    302485 light ivory
    500248 Softwindow light ivory
    500441 Softwindow S light ivory
    2.2 S Targa geminiblue
    2.4 T Targa black
    2.4 S Targa vipergreen
    2.7 RSR tribute green (original 2.4 E 1972)
    Macan GTS black
    Boxter S black
    997 Turbo Cabriolet black
    BMW R 17
    BMW R 69S black with Steib 500
    I believe it should be 901/05 for a 1967 911 Targa...
    Peter Kane
    '72 911S Targa
    Jan 2015
    Bonn, Germany
    Thank you Peter, but now Dr. B. Johnson writes it is a 06 and you and a friend say it is a 05.
    This doesn´t make it easier. Someone else who has a list of engine numbers, perhaps Dave?
    Kind regards.
    Bernd
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
    Quote Originally Posted by softwindow View Post
    Kardex shows the original number is 911523. Is it right that this is an aluminium engine type 901/06? ...Or could it also be a 901/05?
    For the 1967 Model Year:
    901/05...... from 909001 to 911000
    901/06...... from 911001 to 912050
    Jon B.
    Vista, CA
    Oct 2008
    Burford, ON, Canada
    I agree with Jon and Dr. Brett Johnson
    Good discussion...
    Peter Kane
    '72 911S Targa
    A factory chart for early cars...
    Jon B.
    Vista, CA
    Jan 2015
    Bonn, Germany
    Thank you very much for your help.
    Which is the best book to look for detail information?
    Kind regard
    Bernd
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
    Bernd, the factory Technical Specifications booklet for your model year range is a good place to start.
    I don't know if you saw the chart above your post, because you posted one minute after I did.
    Jon B.
    Vista, CA
