Results 1 to 9 of 9
Thread: Original 13mm Sway Bar (Front)
    This is a 13mm set up. Micrometer confirmed 13mm sway bar set up w/drop links.
    $295 + shipping
    sending a pm
    Bump and price drop.
    Oct 2009
    Indiana
    So, am I seeing it correctly? The lever assemblies are not complete? (There are supposed to be 2 side plates with 2 bolts/nuts for each lever.)
    Dec 2008
    Black Mountain, NC
    Quote Originally Posted by mshaver51 View Post
    So, am I seeing it correctly? The lever assemblies are not complete? (There are supposed to be 2 side plates with 2 bolts/nuts.)
    In last pic there should be a "guide plate" (factory stamping x 4 ea) that go's on top & bottom of the bracket as shown (above & below the point of the square) for the M8 clamp bolts, stampings fit into the bracket as well as over the edges of it to apply force to clamp the sway bar. 13 mm bar was for 912.
    May 2005
    Southern California
    In this illustration photo the bolts/nuts are missing, but all else is there.
    9146gt, the parts in your post look to be brand new. Are these restored or brand new?
    May 2005
    Southern California
    Suppose to be 'new', not my parts. Posted pix as a pictorial reference to show the small rectangular brackets...
    Bump - Price reduced.
