Thread: 1972 oil change - anyone use a petcock of sorts ?
    Changing the oil on a 72 is always more "fun". The oil tank plug cannot be accessed with any strength without pulling the rear wheel. But if you do that you're now on my lift and the lift arm is inconveniently right under the drain plug, or close enough I cannot put the pan there and prevent a biblical flood of oil... I used a piece of Rain gutter extension this time to redirect the rapid flow - but I was wondering if any of you installed something easier like a petcock or something that you could get tubing on and not even have to raise the car to do this ? I'm thinking a valve of sorts would be great also in case I overfill a little... wondering if a proven part would fit that plug hole as a bolt -on ?
    Greg.
    72 911T - 73 2002
    #1461
    Aug 2011
    Eugene, OR
    These were popular with BMW forum peeps a few years back. Note that you can get them with various ⅝" nipples to put a hose on them to ease the process. I've not tried one myself yet, but now that I own a '72 and you have pointed this out, I might.
    https://www.fumotooildrainvalve.com/...modelId=560710
    - Arne
    FUMOTO.... That's what I was looking for - could not remember the name from a thread many moons ago - thanks Arne !
    Ordered - $60 all done with extension tubing, caps, extras safety lock, gaskets etc...
    Avoiding exxon valdez in my garage ? Priceless.
    Greg.
    72 911T - 73 2002
    #1461
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I have a Fumoto drain valve on my ‘69 S...works great! It has a safety lock to prevent accidental opening.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
