Results 1 to 10 of 10
Thread: FS: 911 Oil Fitting Assembly, Tch, DN16
    These field-rebuildable, aluminum assemblies were not available separately. The collars and nuts are commonly scarred during servicing. Note that these fittings have threads of M26×1.5 versus the M30 used on later cars.
    They were used on:
    PET '65-'69 911, Fig 1-04-00, #17 901.107.331.12 Breather hose, engine - oil tank Qty: 1
    PET '65-'69 911, Fig 1-04-05, #13 901.107.362.00 Oil pipe, oil cooler bracket, rear, '69- Qty: 1 NLA
    PET '65-'69 911, Fig 1-04-05, #14 901.107.363.00 Oil pipe, oil thermostat - oil cooler, rear, '69- Qty: 1 NLA
    PET '65-'69 911, Fig 1-04-05, #15 901.107.364.00 Oil pipe, oil thermostat - oil cooler (Outer), '69- Qty: 1 SS: 90110736403
    PET '65-'69 911, Fig 1-04-05, #16 901.107.361.10 Breather hose, oil cooler - bracket, front (Inner), '69- Qty: 1
    They were also used on 911ST's and 914-6 GT engine bay oil lines.
    Material: Aluminum, 7075-T6
    Finish: Ra 12µm (As machined)
    Anodized, Type II, Class I (Clear)
    Weight: 47.87 grams
    The price is $53.18 per assembly.
    Shipping within the US is by USPS Priority ($7.90). International shipping is also available.
    Key Words: Technochemie, Argus, Hose end
    Other available parts:
    Feb 2007
    San Diego
    Thanks to JimmyT for manufacturing these great parts. These oil line collars were the key to saving and restoring the original oil lines in my 70 911S. The quality and fit is excellent. I am very happy with the way this turned out.
    Junior Member
    Jun 2021
    Jimmy,
    I need to order from you. Is there a way to contact you?
    Thank you
    I sent you an e-mail. Thanks for your interest.
    Quote Originally Posted by TLing View Post
    Jimmy,
    Thank you
    Senior Member mar2mar's Avatar
    Feb 2003
    Los Angeles
    Jimmy,
    I would like to order hose #15 and #16
    Marlon
    Hello Marlon,
    I am only selling the hose end assemblies, not the complete hose. The original hoses were designed to be rebuildable in the field (vs. replacement). These fittings are used by people who have partially damaged hoses. PM me and I can help with your project.
    Quote Originally Posted by mar2mar View Post
    Jimmy,
    Marlon
    Feb 2003
    Los Angeles
    Hi Jimmy,
    Do i need a special tool to connect this to a hose?
    These assemblies screw on to the end of the hose.
    Useful installation tools would be:
    • Bench vise, 5” or 6” wide
    • Vise soft jaws or wooden jig fixture for holding collar
    • Sharpie, Black
    • Duct tape, silver, 2”
    • Die grinder with thin cut-off wheel
    • Die grinder sanding drums, cones or burrs
    • Air compressor with blow gun
    • Motor oil
    • Grease
    • Wrench, 27mm (or crescent wrench) for 911 Case Adapter
    • String/wire, rag strips
    Hi Jimmy,
    Feb 2003
    Los Angeles
    Thanks Jimmy, I just sent you a PM.
    Jimmy are these M26 fittings still available, sent a PM
