Thread: Steering Coupler - any new versions in use?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Dear all,
    I do want to know, if there are technical updates, which do work, of the steering coupler.
    As far as my poor knowledge goes, i learned the rubber version with the metall inlets does serve as a sort of damper for the steering, too.
    There are some out in the market, which do reverse the construction, or are just as a stiff element.
    Either cnc aluminium, or casted, or else.
    precision matters, f.i. has one developed for the 356.
    https://precisionmatters.biz/steering-coupler.php
    https://www.rsrproducts.com/product-...eering-coupler
    How is the general steering wheel feeling and drivability?
    how is the difference to the rubberized version?
    What is to be used best?
    thank you in advance
    haul
    measurements pics by peter graham
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    any update on this?
    Junior Member
    Aug 2023
    Newbie, hope this is not treading out of line
    Haul,
    I worked with Peter G over on the 912 board to develop unit for use in 9XX cars, I'm told up to '89. It retains the flex and damping of the stock repros, but uses aluminum for the structure, capturing flex elements between two aluminum discs. Upon their failure, it is physically impossible for the coupling to 'separate.
    Ron LaDow
    Jul 2014
    bavaria
    Ron,
    thank you for your precious input
    https://precisionmatters.biz/steerin...er-911-912.php
    I was unfortunately too early with my request at you back in the years, as your „upgrade“ for the 9** series had not been ready yet.
    If I would need a new coupler now, no question which product I would use…
    br
    haul
    erwin_loves_polo
