Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 119
Thread: $1K 68 Sportomatic
  1. #81
    May 2019
    Fredericksburg VA
    Our local dump has a Hazmat drop off day 2 time a year. I have the nasty stuff in milk jugs and drop them off. Not too bad as long as you make the date.
    I wear a respirator, gloves, jacket, goggles and did it outside. Only brought in to take the pictures. I will strain the chemicals and pour them back into the glass jug for safe keeping. I do not plan to use this much. More of a 1 or 2 times a year kind of thing.
  2. #82
    May 2019
    Fredericksburg VA
    Yeah Baby, Upgraded power supply , 4 anodes, rotate every 5 min, hand and flip. May have had the amps up a touch too high but looks good.
  3. #83
    That looks pretty good. What amperage did you have it set to and how long overall?
    I'm finding the anodes on all sides or in the very least larger make a big difference. I recently purchased more. I hadn't noticed how thin and ragged mine had become. Better then half the overall thickness was gone.
  4. #84
    May 2019
    Fredericksburg VA
    I ran 14.5 and plated for 20 min. rotated and flipped every 5 min or so.
  5. #85
    May 2019
    Fredericksburg VA
    Dang, old thin gauge sheet metal is tough to work with. The metal is so thin, there is not enough to weld to. Keeps opening up. I'm using thin filler rod and low amps on the TIG machine.
    I twisted 2 pieces of MIG .030 wire together for the filler rod. I have 1/16" but even that is too thick.
    I had to do a little rust repair. I have plenty of time to locate another if I can't get this. I would be fine if I was going to powder coat it. I could finish sanding and fill the rest of the pin holes. But I plan on plating it and need it to be solid.
    Maybe for now I will get it the best I can, powder coat it and call it god for now. Pick up a good one some day and all will be good.
  6. #86
    May 2019
    Fredericksburg VA
    Did some powder coating today in my Easy Bake Oven. Looked good.
  7. #87
    May 2019
    Fredericksburg VA
    Finally after many attempts to get it correct. The larger power supply helped.
    The calipers are complete. Well, almost. Still waiting on some pads, clips and bleeder valve
  8. #88
    The brake pad retaining pins and spring look horrible.
    They look too rough.
    Just buy new.
    But you did a nice job on the caliper itself.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
  9. #89
    May 2019
    Fredericksburg VA
    I have new pins, clips and springs on the way with pads from PMB.
  10. #90
    May 2019
    Fredericksburg VA
    Finished the brakes, now to start on the steering rack.
    It was nice and tight but still wanted to clean the bearing and repack.
    Dang, Had a heck of a time getting one of the inner tie rod ends off. The large nut was rusted the the locking plate and would not budge.
    Had to take a grinder to the tie rod end so a 3/4" drive socket would fit. Some heat and and 3/4" impact gun was able to break it loose.
    I made a quick puller fashioned after the original one in the Porsche manual. However mine was made from a 1/2" bolt, nuts, a metric coupling, and a piece of exhaust pipe. Worked like a charm and for under $4. SWEET.
    Cleaned and plated, now ready for reassembly.
