Results 1 to 10 of 15
Thread: SWB rear deck-lid grill rubber strips
    Hi,
    I am in the process of mounting the rear grill on my deck-lid. The factory used 4 I believe rubber strips about 1 cm wide between the grill and the deck lid. I have misplaced mine, so am hoping that someone might be able to tell me the total length of them and whether they had a hole in them for the grill studs.
    many thanks,
    JK
    I have four originals set aside for 65 resto, but am traveling thru Wednesday. If no one responds I'll dig them out and provide dimensions when I get back.....
    John Schiavone
    Connecticut
    Thanks John, that would be very much appreciated
    Under grille spacer
    I'm not sure about the rubber version of the under grille spacers - but as a comparison the 1964 version was a injected plastic piece that looks like this:
    (These were found on the 20 mm tall grilles on the early cars). I would guess the fitted 15mm grille (spring 1965 > ) to have a spacer close to this perch size - m14 x 202 or 12 x 200. Lets see what the measure is.
    Bob
    Early S Reg #370
    Hi Bob, thanks a lot for the pointer. Boy, I guess I should be happy in some way that I do not have a real early car. I would probably be tearing my head out right now on how to duplicate the strips shown in your picture. Actually, if someone out there is looking to have this piece made I would know of a good place to check with. He is a 356 guy who does amazing work and owns a injection molding company.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    the parts are already available as 3d prints......
    br
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    Great......something else I didn't know I needed
    JK, others:
    Here are the dimensions, taken from #1744. Please let me know if you find material or decide to make others. I can use 8 for two 65s. Thanks
    John Schiavone
    Connecticut
    Thanks John.
    One more piece of the puzzle found and documented. Good Stuff.
    Bob
    Early S Reg #370
    Thought I get back on this. I found some 3mm rubber sheet on ali express. Some time with a straight edge, fresh razors and a belt punch will give you the strips. Will post some pictures of the installation when I get to it. Focus right now is on the interior of the car
