Thread: 1967S rear garnish rail SETS, targa too
    I’ve perused this site, googled as well and best I can tell is these are rare and legit pieces.
    Both sets feature a nicer more specialized vinyl texture than any of my others (the others are smoother vinyl texture for sure). With the bent ends - they seem to be ‘67S items, and the larger set is apparently the soft window targa specialized pieces. They are literally flawless in terms of rips, tears, stretches, etc. still pliable and just need gluing down around the ends. Look closely at the photos, those aren’t scrapes or scuffs (the discolored bits) it is simply discoloring and I am sure there is a way to ‘blacken’ over this.
    ‘Targa’ set ask is $600. for the pair
    The coupe set ask is $450. for the pair
    Plus associated costs.
    Rear garnish rails - 67S. Original rails, look to have been recovered in house with factory vinyl. I have a big roll of it, so I will cut off an ample amount so the unfinished one can be matched or you could use the present covered one as a pattern and start with new material on both. I will provide enough material for that.
    Ask is $275. for the pair
    These may fit ‘68 year variant cars too?
