Page 13 of 37 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 366
  1. #121
    Jan 2014
    Le Mans, France
    http://www.garagebourgoin.com/Restau...F/DSC_3027.JPG
    Have you asked the Garage Bourgoin, about the cell fuel?
    http://www.garagebourgoin.com/Restau.../911-21-1.html
    This is the R5 replica made from the original parts left after the restoration of R5 in the its Dijon 1,000 km 1973 configuration.
    info@garagebourgoin.com
  2. #122
    Mar 2007
    Melbourne, AUS
    Thanks Heaps! I just sent them an email in my bestest French (thanks Google).
    Let's see what they say.
    Little update; I noticed I made a mistake in my wiring harness order; I ordered the standard fuel pump harness, and not only do I need two of them, in the 'standard' 1973 car the pump is located in the engine bay, so the harness connects to the 'front to aft' wiring loom, whereas for the RSR both sit in the front and connect straight into the fuse panel in the front left wing (see example). Anyway, that's easy enough to fix. The first layer of primer was applied and we're now fixing more irregularities to make the boy as smooth as possible.
    It's starting to look like a car again!
    Name:  Hill Country 2007 008.jpg
Size:  86.3 KBName:  IMG_4267.jpg
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
  3. #123
    Aug 2013
    AZ, UK, FR
    Looking great! Have some of the small brake fluid bottles when you get there... pretty sure I have the big ones in a box somewhere...
    https://www.early911sregistry.org/fo...=1#post1049323
  4. #124
    Mar 2007
    Melbourne, AUS
    Thanks, but i already bought those a while ago
    Member #3508
    1973 911 2.4T
  5. #125
    Jan 2014
    Le Mans, France
    Collecting vintage dymos is just a side effect....
    I think I have the wheel for my dymo 1540 to write vertical too
    A little off topic, but do you know a reference of 1980's Dymo that can write on 24mm tape?
    I will need one
  6. #126
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    24mm is a lot. So no hobby rather a professional application. Sorry I don't have any Ifos on them.
    But I have one that can emboss thin stainless sheet metal in case you'd need that.
  7. #127
    Jan 2014
    Le Mans, France
    Thank you for your help.
    I will check if it's 19 or 24 mm, but I'm sure that it wasn't 9 or 12 mm as usually found.
    Here is an example of what I would like to be able to do:
    Name:  IMG_1094 - Copie.JPG
    A friend of mine owns another H project 928
  8. #128
    Mar 2007
    Melbourne, AUS
    Another question I hope someone here can answer.
    The works (and on request, some customer) RSRs in 1973 had the 120L FT3 safety fuel cell, but on pictures there's another (smaller) tank visible behind it, more toward the driver side.
    Anyone know what this is and what it is for?
Size:  74.6 KBName:  55404047.75rsr041701.jpg
Size:  99.8 KBName:  IMG_7993_360_0894.JPG
    From the white car it is more obvious this is, just like the fuel cell, made off glass-reinforced plastic (fibreglass).
    Member #3508
    1973 911 2.4T
  9. #129
    May 2014
    South East USA
    alrighty.
    What did H21 EPA mean?
    Do I need this on my car?
  10. #130
    Mar 2007
    Melbourne, AUS
    Guys, can I ask you to maybe start a separate topic for it or do this via messages?
    I'd like to keep this topic purely for things/parts related to replicating a works 2.8RSR as best as possible.
    thanks!
    Member #3508
    1973 911 2.4T
