Results 1 to 9 of 9
Thread: RSR engine info
    RSR engine info
    Hi,
    I can buy a rsr 3.0 engine in Germany, 911/75 block and number *6841734
    I would like to buy it for a 1972 911s rsr conversion car.
    Does anyone know how to get some info or history on that engine?
    And if I can find out which car it belonged to?
    Thanks in advance.
    Cheers,
    Nico
    Oct 2008
    Burford, ON, Canada
    6841734 sounds rather fishy to me. The highest I have heard of is 6840169 and that seems to be a bit high. Please check that serial # very carefully, and get photos; very good photos to be able to confirm.
    slide valve system seems to be billet machined -> not really original I guess
    the injection pump is not an rsr one, maybe the 3D cam is ok but missing the red plug and some other details
    the distributor has a bosch orange cover, maybe original but for a 72 2.8 proto inspiration this should have a marelli one
    the oil filter is a 993 one not the micrometalic original one
    valve cover are not 70's, probably 993 (TBC)
    cam cover are not centerlub, not original to an rsr
    engine Nr seems to ne to bright to be real.
    who knows what is inside...
    for this big amount of cash you can have a really nice engine build that will be perfectly ok for your project.
    Thanks again for the feedback! The bright numbers scared me and I wanted comfirmation...
    Senior Member RennTyp's Avatar
    Apr 2006
    Oxford, UK
    engine number is definitely restamped
    Early 911S Registry #888
    Die cast engine case instead of sand cast. No cam center oil. Not sure it’s worth the asking price.
    Jan 2016
    Bad Münstereifel--Germany
    Hallo Nico.
    70k is a lott of money.....i think 40-50k you can buy a verry good engine by Mittelmotor in Bochum....a oem 3.0 engin is intressant for an oem 3.0 RSR?
    Gruß Harry
    Guys, thanks for the feedback.
    So restamped numbers (why would someone do this?) and die cast - should be sand cast?
    Not the correct pump and some 964 or 993 parts mixed in a RSR period engine?
    I will go and talk about this with the seller, seems weird...
    A partial trade was proposed: 35k + a high end track e46 M3 car which is also 35k, this makes it interesting for me, otherwise I would have backed out only by seeing the bright numbers...
    Senior Member VZ935's Avatar
    Aug 2009
    SF Bay Area
    70K for a 74 RSR engine? That is your first clue. The engine cases for an RSR are unique and depending on condition, number , what it is numbered to, or no numbers they sell for 30K on the low side to 50K just for the case
    A few photo for reference
    935 Owners Registry #02
    1969 911S, 1970 Euro 914-6
    935 1978
    Copeman Porsche 911 IMSA GTO
    1981 924 Carrera GT
